Johnson 35 HP wiring question....
F_R
Honorary Supreme Mariner
How do I determine where the top and bottom cylinders are in correlation to the coil packs on the Magneto once the flywheel is removed? Is the back coil always the top cylinder?
If you have the external coils mixed up, it will not run at all because it will be firing at the bottom of the stroke.
Fatguynalittleboat...
The motor runs....and it did run at full throttle.
I'm trying to figure out why I can't get it to go past half throttle now.
I can turn the throttle to wide open but I still only get half power
