Fatguynalittleboat...
- May 12, 2013
- 62
I bought an 1988 16' lund fishing boat. It needs some sprucing up, but I'm on top of it. Got it on the cheap....Really cheap!!! He was an older retired fella that used it everyday...He'd won a walleye tourney up here in Wisconsin and his prize was a new Lund 18"....So I got it for less than $500.
I need to re-wire much of the motor.....Wires are so old and frayed up that they won't hold constant current.
My question is....
The 1977 25-35 HPJohnson service manual wiring diagram shows two red wires coming off of the positive terminal on the starter solenoid.....One is for a 20 AMP in-line fuse (I believe....Please correct me if I'm mistaken) ....
The other wire in the diagram goes nowhere at all....Does it just terminate? Do I need to connect this red wire to anything.
My motor is a 35ELL77H...I've had the motor running...But it is rough and intermittent....Some times it starts right up....Other times it will only turn over. (No spark to the plugs) I believe putting some new wires from the bottom half of the 5 wire waterproof rubber connector will solve the issues I'm having.
Can anyone tell me what this wire is for?
Thanks in advance.....
My question is....
