johnson 30 hp
roger m
would like to find year of motot<br />md #vj30eless sn#r08599519<br />also need help with what might be wrong with<br /> spark,runs ok up to 4000 rpm and then misses<br />till slow down to 1000.<br />i had a friend swease the primer bulb made no change<br /> new plugs,fuel and filters :confused:
Bear
Re: johnson 30 hp
vj30eless<br />v=Boat builder<br />j=Johnson<br />30=30 hp<br />e=Electric Start<br />l=Shaft Lenght 20"<br />es= year 1990<br />s=model run or suffix
Bear
Re: johnson 30 hp
swease :confused: <br /><br />Lack of fuel. Did you open the vent screw on the tank cap?<br />Try pumping the bulb. Maybe the fuel pump.<br />Or a stuck carb float.<br />New filter huh? Did you tighten the ... things on the fuel line? Maybe an air leak.
roger m
Re: johnson 30 hp
the vent on top of the can is open,<br />but i have not cut clamps off the hose yet and put on some new ones.<br />it seems to run well at all speeds under 4000 rpm<br />ran it over 40 mins<br /> :eek: :eek:
