blublastercod
Thread starter- Joined
- Jun 9, 2009
- 3
I was running about 18 mph when the motor hit a stump and kicked the motor up out of the water. The motor was turned off and positioned back into the water and cranked back up, the water pump was working fine and the motor runs at trolling speed with no problems. The motor will not run at a higher speed with out skipping. When throttled up the motor will skip about every 2 seconds. The prop does not appear to have any damage, any suggestions on what this hard jolt did to this once fine running machine? Thank you. model J30ELEEC sep 1998
