I have had a Johnson 30 2 stroke for a few years and it has done great. I needed some general maintenance done, so I had engine serviced and I had the throttle and gear cables replaced. Since getting boat back I have had two issues.
1. Today I took boat fishing. I noticed the engine had been getting weaker and weaker at starting, but I knew the battery was fully charged. While I was concerned with this I did not see an immediate threat. One hour into day today I decided to change fishing spots. When I started motor it sounded like it barely had enough power to get it to crank. The engine started immediately, but the issue with was the feeding the motor the electrical power it needed to let the motor fire up. I decided to take it back to ramp to check it out instead of risking my luck. I tried starting again when I got back to ramp and it gave me nothing.
I pulled the boat out and looked into the issue. The throttle/gear lever had been loosening over the last couple trips (bad service work issue) so I thought it may not have been in neutral. I pushed the lever back and forth a few times to make sure it was in neutral. I tried to start again and the boat cranked, which I immediatley cut off afterwards. I don't recall how much "juice" it sounded like it was getting at start, but it started quickly.
I then pulled off gear/throttle box and tightened lever appropriately. It was a simple Allen nut on back to tighten lever so it was very easy. I had no need to open up gear/throttle housing to expose internal components. I put the housing back on boat with two bolts and now the engine does absolutely nothing. It use to make a slight beep when I turned the key to the "on" or "accessory" switch, but now I get nothing. I got home and opened up the housing to look for anything suspicious, but I don't know what I am looking for.
2. Boat has been revving up when I try to give it enough gas just to plane out. It worked first day after I got the boat back, for about 5 minutes. Then it just starts revving up very high without gaining power. In lower speeds it does just fine.
I am more concerned with the first issue. Could it be neutral safety switch? Solenoid? Help please. Thanks
