Johnson 2hp Sea Horse, J2RC1B, E5375517. What year is this motor and what oil mix should be used. I've rebuilt the carb, there is a slow and fast adjustment knobs, where should I start the adjustment of these two needle valves.
J2RC1B<br />J2RCIB is a 2 HP Johnson 1981 (1981 - CI)<br />Mix 50:1<br /> Exploded views <br /><br />Start with the low speed jet. Fully seated (carefully) and one turn out. Try to start. Adjust 1/8 turn att the time. Allow the engine to response to your adjustments, some 20 seconds or so. When you are satisfied about the idle and low speed you start with the high speed jet.<br /><br />Fully seated (carefully) and 1 - 1 1/2 turn out.
