Richard Kevin
- Jul 6, 2001
- 3
I have a '75 Johnson 2HP. I took it in for a carb rebuild because it wouldn't run at all w/o half choke and wouldn't idle. Same problem occured after one or two uses. NextI rebuilt carb myself (the shop had not put in new parts) Initially it ran fine w/ throttle open but still wouldn't idle. Adjusting slow speed jet didn't help. After a short test run it again started stalling unless I kept it on half choke. Any suggestions? None of the local shops will work on a motor this old.
