I have a 25hp Johnson, 75 model I believe with a pull start. I've been looking for instruction on the assembly for the gears in the tiller. Specifically the gears that are on the engine that mesh with the throttle arm that's bolted to the engine block. When I twist the throttle to full power it doesn't open the butterfly and when I twist it further is disengages, gear slips. I've looked around the net and have yet to find a description/instructions to set it. No teeth are missing from either gear. I'm at a loss
What I'm working on are parts 109 and 52 in the diagram
