Johnson 25HP Seahorse 1973 Slow speed link and reverse issues
wethcr88
I recently purchased a 25R73A outboard, it seems to run well except that idling seems to cause it to die. I found that the link between the slow speed lean/rich knob and the knob on the carb is missing causing the lean/rich knob to be useless.
Is this a part that I can fabricate myself? I was hoping to just take some small steel tubing and bend it around the holes so it stays in place.
It also seems to have an issue staying in reverse. I have to apply quite a bit of pressure on the shift lever to keep it in gear. Forward and neutral are fine.
F_R
Honorary Supreme Mariner
The link is part number 314689, but listed as not available. Reverse problem sounds like somebody has turned the clutch dog around to "fix" a not staying in forward gear problem. Holding it in gear will only make matters worse by putting a strain on the shifting linkages and messing those up.
wethcr88
Thanks for the advice. It looks like the cost is about $115. The motor came with the boat, 14 foot Lund deep V. Is it worth replacing the clutch dog or should I look into finding a different outboard? Assuming that is for sure what it is. Would have to tear it apart to check the wear.
