suttonc311
Thread starter- Joined
- Aug 24, 2009
- 12
I just purchased a 2005 Johnson 25 hp electric start J25TELSOM with both short and long shaft. The engine was originally purchased with the longshaft attached but the original owner had a mechanic swap out to short shaft. I needed it back to a long shaft so I converted it. Long story short, the driveshaft for the long shaft does not fit into the pinion gear in the gearcase. I see that there are two different pinion gears. Is there a way to avoid swapping the pinion gear out? Or, what is the easiest way of replacing the pinion gear? Can it be accessed below the water pump and bearings? Thanks in advance!
