Bendellaria
Thread starter- Joined
- Oct 7, 2018
- 6
Ok so I'm hoping someone can help me. I have a 1993 Johnson 25 hp. Electric start. And after it warms up it will have a lean sneeze from what I can understand and then it will stall hard and after a few times of it stalling it gets harder to start it only does this at idle. Once I get it started it will run fine off of idle and always runs fine off of idle top end is plenty of power. I have replaced plugs thermostat and springs. Gone through carb and removed welch plugs to clean ports. Checked leaf valves in intake. Retuned carb a million times in water under load. I used acetelyne torch to find vacuum leaks on case or seals seemed to be problem at lower crank seal removed power head and re sealed lower crank seal along with upper crank seal. But still have no luck getting this to run correct at idle any info would be appreciated. Thank you
