Johnson 24 Volt Trolling motor help
demolitionman13
I have an older Johnson 24 Volt trolling motor, model number BF4PV97. Apparently, the front seal went out and the motor filled with water, causing everything to rust up. I disassembled everything and cleaned it, but something is not right. It will run if you manually spin the prop, but is not turning as it should. I think the spacing of the armature may be off. There is some in and out movement of the shaft with the prop installed. Does anyone have any ideas where I could go from here, or how much it would cost to have the motor rebuilt?
Thanks,
Shane
