Johnson 225 no spark please help !!
Tufftymolly
Hello all ,
I'm helping a friend with a 1990 225 that has no spark.
He noticed it running rough then a little later , just died on him.
I found a spark plug wire that had disconnected from the coil but the main engine fuse wasn't blown,turns over and 75 psi in each cylinder.
Any help would be great.
Thanks
Tufftymolly
Sorry about the delay ,I didn't think I had a reply.
All cylinders no spark, but thanks for the link, I'll give it a shot but I think that the issue stems from the plug wire coming out of the cap and shorting something out.
Thanks again for the help.
sutor623
First thing to check is the black and yellow wire. That is the stop circuit. If that wire is grounded (coming from the switch) it will turn he motor off and prevent any spark.
