Johnson 20RL71S Driveshaft Question
Rrosenbloom
As I continue to explore the "new" old motor I bought, I was checking the impellar and wasn't able to slip it off the driveshaft over the top, so I just pulled the drive shaft out and removed it from the bottom. I put everything back together and didn't notice anything wrong, but when researching replacing seals and whatnot I came across an instruction that says if you pull the driveshaft out, you have to disassemble the gear box and align the pinion with the shaft..etc. That true? I can turn the driveshaft with my hand and it grabs gears and spins the prop forward and reverse.
F_R
Honorary Supreme Mariner
That is BS. No problem with pulling the shaft out. The BS story comes from the 3hp, where indeed you can't get it back in---unless you know how! Then still no problem.
Rrosenbloom
I was nervous, but since everything went right back into place and felt connected, I thought (was hoping) maybe that step applied to something else. Thanks for the reply!
