Cowboy_667
Thread starter- Joined
- Jan 5, 2016
- 1
Motor is a BJ115VLSIF carbureted 115hp Ocean Pro. Been running sweet and then started surging. Believed it was fuel related. Got rid of a small air leak, replaced filter and primer. Seemed to settle down when these changes made and changed from underfloor tank to tote. Played up again. Typically after five minutes running and over 4000 rpm. Checked fuel pump and found oil and fuel on vacuum side of pump so replaced pump. Still doing it. Since then had a plug fail , electrode came loose causing three cylinder running. Thought we were onto it and replaced all plugs. Still doing it. Had carburettors serviced with one with a badly out float level. Still doing it. Checked grey spark plug leads. All around 550 ohms. One at 650. Running out of ideas. Any suggestions?
