First time, So sorry if I could not find this topic. My engine Johnson 200 ocean pro year 2000, ran great across lake then died, pumped the primer bulb and ran again until it burned that fuel. My buddy had to sit in the back and squeeze the primer bulb all the way back to dock.
The NO OIL light came on also, but the oil tank was full. Gas tank 1/2 full. No air leaks detected. I replaced the primer bulb today and got the same results, runs good then dies.....squeeze the primer bulb and it starts right up and runs.
Could it be the fuel pump? Possible hole in the diaphragm ?
2000 Johnson Ocean Pro 200 HP
