Johnson 2-stroke 9.9 1990 outboard gas pump question
stijnb
Recently I ordered a new gas pump for my 9.9-2stroke outboard. The pump was leaking and looked like replacement was the best option. The new (OEM) pump did not include a gasket (between pump and engine). Is this important? The missing gasket is seen on this image: http://www.go2marine.com/docs/1/5/4/6/154611F-p.jpg
Thanks!
dazk14
Ensign
Your link did not come thru.
Yes, you need the gasket , since it seals the center of the fuel pump to the crankcase for pressure/vac pulses.
stijnb
Sorry, image attached now (right gasket), but I'm guessing it is necessary! Thanks for the replies
