Johnson 2.5 Water tube assembly?
DaveWave365
I have a new-to-me Johnson 2.5 (J3RCUA). I replaced the water pump impeller.
During reassembly, I noticed that the water tube (see picture 1), is quite small, about 1/4 " (cut at an angle). However, the grommet in the water pump has an inner diameter of about 1/2 ". So on reassembly, If I insert the tube into the grommet, it is just going to flop around and most of the water will bypass the tube.
I checked the parts diagram and I do not seem to be missing any parts.
Is this correct or am I missing a grommet that fits onto the lower portion of the water tube?
Thanks !
-Dave
Joe Reeves
Wrong grommet, possibly wrong housing. It needs to be a tight fit (tube to grommet) otherwise, obviously the engine will be prone to overheating.
DaveWave365
Got in sorted.
I started thinking about a wrong part. Closer examination shows the grommet has an internal taper. Checking with a drill and calipers shows a snug fit.
Thanks!
-Dave
