I just bought a Johnson 2.3hp motor it is in immaculate condition hardly been run at all (AFAIK) and been told not even been broken in. Has been standing in a dry area for some time.
S/n number of engine is 09370277
Model number BJ2REU(D)
Year 1997
The problem i have is that i can't start it.
This is what i have done: -
**Checked the spark and there is one.
**Removed the fuel tank and fuel leads to check for fuel flow, all good
**Fuel vent is open on the top!
**Cleaned the spark plug for good measure
**heated the spark plug and tried to start it no good
the only thing i think it can be in the carb, but i know very little about them so a few questions.
1) If i take the spark plug out of the block and pull it a few times should i see any trace of fuel being ejected?
2) How can i tell if fuel is going through the carb without rebuilding it (am assuming i can't)
3) what should i check for if i dismantle the carb?, is it just taking the bowl off then clearing all the gunk out if there is any?
4) having done some reading tonight could it be a stuck float that is not drawing fuel?
Over to the experts, i thank you all in advance for any help you can give me!!
Tarwddu
Year 1997
Tarwddu
