Re: Johnson 1990 GT150 lower jets
Welcome to iboats. seeing it's been sitting 2 years, you need to go thru the awakening process, install a new impeller, dismantle the carbs completely, removing all the jets, soaking in carb cleaner, blowing out with compressed air, and reassembly with a new carb rebuild kit. thats just from sitting 2 years.
99% chance your problem is cause by dirty high speed jets, or a weak fuel pump, air leak in the fuel line, closed vent on the gas tank. having to choke the engine, means it is not getting enough fuel to run at high speeds.
if careful not to move the linkage you should not have to do a link n sink. you can go to brp-johnson, engine diagrams to view a blow up of all engine parts. the jets are hidden behind plugs that have to be removed, and you need a special tools to remove the jets, the tool can be made from a quality screwdriver. there are no dumb questions here, so ask. heres a couple of links.
http://forums.iboats.com/showthread.php?t=158086
http://www.evinrude.com/en-US/Accessories/Literature/
http://i155.photobucket.com/albums/s311/frankr_photos/FixedJetScrewdriver2.jpg?t=1177353186
parts can be bought from the dealer, online, but, we like to support the benefactor of this free forum, buy buying from the i boats marine store at the top of the page. clik johnson parts.
