Martin Devault
Thread starter- Joined
- Nov 3, 2013
- 6
Hello
I was out on water for maybe a hour and everything was allright when suddendly, the speed go down. When i push the gas to the top, it's going may be half of the speed he should go. At idlle, it shut off but always able to restart it. A little bite like if only 1 or 2 piston are working. I though easy one, spark plug. So i check and all of them fire. Compression 120,116,120 pretty good. I don't see anything in my 2 books. Because of the spark plug fire, and compression is good, do you think it's a carb problem, like something pass in the gas line and blocking a hole ? I have to say i change my waterpump and the thermostat last fall, i don't think it's have anything to do but i no expert.
thank you in advance
MD
MD
