Johnson 1985 30hp not running
Andrew7hockey
I have a 1985 Johnson 30hp out board that just had a decent amount of work done to (rebuilt carbs, new spark plugs, new water pump and impeller, some new gaskets) but now it won't work. I got my motor back from the shop around 2 months ago. It ran fine and had no problems with it except some times the motor would be running at full speed and would fluxuate speeds. Once I pumped the primer ball this went away. Recently I took the boat out and it turned right over but about 10 minutes into the trip it died and we couldn't get it to start up again. Eventually we got it to start for about 15 seconds before it died out again. Now it won't turn over at all. Any suggestions would help. Thanks!
