bonitasprings
Thread starter- Joined
- Dec 24, 2009
- 42
No spark on #1. I've done the following:
replaced plugs
replaced plug wires
replaced coil
replaced powerpack
tested for continuity (ohm) -- OK
tested for shorts -- OK
Checked all grounds -- OK
Checked polarity -- OK
Spark at other 3 cylinders
swapped sides powerpack-problem didn't move
swapped sides with a known good coil-problem didn't move
gone as far as I can with the equip/money I have. pulling flywheel soon to check condition/wiring underneath. Before I got it it had fried an egition circuit...blew a 30 amp fuse. What could cause that? What am I looking for under the flywheel?
Don't have a CD tester. Someone mentioned that there is an adapter for a voltmeter that can measure the stator. Where can I get one and what do I ask for?
Thanks Tim
replaced plugs
replaced plug wires
replaced coil
replaced powerpack
Thanks Tim
