I had the lower unit off standing upright in a bucket waiting on my new water pump which came in today. I did pull the drive shaft out prior to installing the water pump but replaced it before starting. It slide in easily but floats up a bit due to fluid pressure it appears. I noticed some lower unit fluid in the bucket but thought that i had spilled some when i did the initial fill so didn't worry about it. Did the water pump install and mounted the lower unit back on the engine. All good until i noticed oil weeping out of this very small hole at the bottom of the lower unit. Attached a drawing showing the location of the hole. Did i pump up some oil somewhere when i removed and replaced the drive shaft? Your thoughts ?
