Johnson 1965 v4 75hp (timeing marks)?
rocketman
please can someone tell me where to find the timing marks on the flywheel of my 75hp 1965 v4 Johnson. This baot has been sitting forten years and I changed the belt and would like to set the timming but not sure where the mark on the flywheel is? I know where the marks are located on the detributer. There is a letter N stamped on the top of the flywheel but not sure if this is the right mark? With a screwdriver in the cylinder and the mark lined up with the stamped N on flywheel the piston still has a ways to go befor it is at TDC could be the right mark ??
Tracy Coleman
Re: Johnson 1965 v4 75hp (timeing marks)?
Rocketman<br />The flywheel has a cast in "line" under the starter ring gear. The block, actually the bolted on piece that covers the top of the block between the cylinders, has a cast in "line". These line up about where the flywheel mark and the belt running toward the flywheel meet. The distributor pulley has a marked tooth and there is a cast in "line" on the distrib. bracket, these line up but all 4 marks do not line together, 2 pair lined up at the same time. Points at .020, plugs at .030. Distrib. pulley should have a washer under the "star" lock washer to keep it from "eating" into the pulley, check for worn keyways in the pulley and distrib. shaft. <br />Backfire ;)
