FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
My motor starts fine but in the lake it bogs at full throttle I pump the ball and it acted like it wanted to go but didn't then the hose at the tank came off ( kick it or something ) but as it started to run good then run out of gas any Ideas
Hose coming off at the tank is a good place to start. Get that on there so it stays on and try it again. Sounds like a fuel starvation problem and a disconnected fuel hose will tend to cause that.
It run like that for a long time on the way in I Was pumping the ball when I kick it off but not on purpose
then it started running good .feels like it went straight to go but won't
Might have been sucking air because it wasn't connected properly.
I assume you have fresh gas in it (this time of year a lot of motors run bad on last year's gas), and had the tank vent open. Try hooking it up again and see if it runs, but starving at wide open throttle often means the fuel pump is starting to go.
