Hi all,<br /><br />My 1st post. I just purchased a 1957 Johnson Sea Horse 7.5 HP, Model AD-11. We got it started just fine, but when we splashed it and put it in gear, it barely made headway speed. I noticed quite a bit of fuel leaking out of the coupling; it appeared that there was a blockage preventing adequate fuel from getting to the motor. I looked at the male (engine mounted) connectors and could not see a passage hole. They almost looked solid. I poked at them gently with a scratch awl, but still could not see a passage. A lot of pressure also built up in the fuel tank, which I relieved periodically. I tried every possible combination of rich/lean mix and fuel tank pressure, but could not get the thing up to speed. I had a couple of very brief moments when the engine started to pick up speed, but then it immediately died.<br /><br />Do I need to replace something, ordo I have a blockage? Any help would be greatly appreciated; I'm a bit of a novice when it comes to outboard engines, especially old ones.<br /><br />Thanks-
