Johnson 1956 AD-10: Shaft and Shifter Seal Replacement?
1956ad10
I just went from top to bottom of my 1956 AD-10 and put it all back together. I made a list of the gaskets, o-rings, seals, and parts I want to order. But I am scratching my head whether I need to replace the drive shaft and shifter seals? How can I tell if they need to be done or not? They felt tight in removing the water pump and in dropping the lower gear unit respectively...and there was no water in the gear oil. I will replace the spaghetti gasket and add sealant to the drive shaft o-ring when I get my parts and pull it apart again.
Thanks for your guidance! (And what a GREAT engine!!!)
Honorary Supreme Mariner
Actually the shift rod o-ring can be replaced without removing the bushing ./ holder.---------Most folks will use the special tool to drive the bushing out.-----Some will run a 5/16-NC tap in there for 3 threads to pull the bushing out.-----I have used all 3 methods.----The top of the driveshaft has a carbon seal with an o-ring.-------Powerhead needs to be removed to do the waterpump impeller.-------Yes they are a very good engine if looked after.
