Johnson 1952 TN-28
rasass2000
I am missing the rotary valve and cant find one. Any ideas on a part number I have the old pn is 42-36. The low speed jet is there but the hole going into it is empty. I believe there should be a stem that it would screw in towards to adjust low speed and fuel come out it when started. Any help would be appreciated. I will upload a picture of what I am talking about later. Thanks
rasass2000
As soon as my battery charges I will get some pictures. The piece that screws into has an open hole in the center. I can see the tip of the needle through that hole when I turn in the jet.
rasass2000
Okay so i'm getting gas out of it should I take carburetor off and clean it then?
F_R
Honorary Supreme Mariner
The idle air and fuel goes through that device, and then the rotary valve in the crankshaft. The high speed air and fuel goes through the third port design in the cylinders. Dual carburetors if you want to think of it that way.
Chinewalker
If you're getting a lot of fuel out of it - and everything elsenis good - it could indicate a worn center main bearing.
rasass2000
Thanks everyone I took carb off and cleaned go and filter screen in tank. It now purrs and I also set jets and it idles down to stop also revs up good. Again thanks everyone going fishing. This is my new trolling motor for my 1971 Penn Yann which I am running original 1971 125 evinrude.
