1_Pull_Wonda
Thread starter- Joined
- Jun 20, 2008
- 11
I would like to increase the power/compression of my JW-10. Currently, the compression is reading about 90 lbs (if my gauge is accurate) in both cylinders. The compression increases to about 145 lbs (if my gauge is accurate) when adding 2 cycle oil to the combustion chambers, testing the engine with it laying horizontal and combustion chambers facing up.....oil uniformly sealing the combustion chamber.
Option #1 Inner diameter & outer diameter of piston ring is standard size, standard size piston
Replace the old, standard sized piston rings with new, standard sized piston rings (part #378412).
In this particular case, compression could be increased by replacing the worn out rings. I believe that the cylinders should be honed & "cross hatched" before installing the old, cleaned standard size pistons & standard size piston ring assemblies.
Option #2 Inner diameter of piston ring is standard size, outer diameter of piston ring is over sized, standard size piston
Is there a point where too much honing will force me to go with over sized piston rings ? Or, if the cylinder walls are scored to the point where boring them out is appropriate, I guess I'll have to go with over sized piston rings (part #378414).
In this particular case, compression could be increased by replacing the worn out standard size piston rings with new over sized rings and creating a clean, uniform cylinder walls with very little space between the over sized piston rings and cylinder walls.
Option #3
If the cylinders are in very bad shape, have them bored way out and go with over sized pistons and way over sized piston rings
In this particular case, compression could be increased by replacing the worn out standard sized piston rings with way over sized piston rings, using over sized pistons to accommodate the way over sized piston rings and creating clean, uniform cylinder walls with very little space between the way over sized piston rings/over sized pistons and cylinder walls.
I think all 3 options are viable as long as parts are available. Were over sized pistons ever made for this engine ? If they were made, does any one know the part number ? What size piston rings would fit the over sized pistons ? And, does anyone have part #s and/or specs ?
Does anyone know what the compression of these engines were right out of the factory ?
Wow.....that was lot to say. Any knowledgeable and wise advice is appreciated !
Option #3
