I have a Johnson 15r79e Outboard. There is a tremendous amount of oil leaking out of the gear case so I am planning on either replacing the seals or buying a reconditioned lower unit.
The issue I have is that I don't own any of the proprietary tools for achieving this process.
Does anyone know of any tutorials on opening the gearcase and replacing the seals and rings?
I have the lower unit off the motor and the gearcase cover seems to be seized onto the propeller housing as well.
What would you recommend? Should I just replace the whole thing?
Full replacement is probably not such a bad idea as I have found an inexpensive lower unit ($125 plus shipping) which the seller guarantees.
Thoughts?
Thoughts?
