Joe Reeves
- Feb 24, 2002
- 13,262
Re: Johnson 15hp bogging down
There is a brass fixed high speed jet in the bottom nozzle portion of the upper body. Did you actually remove that jet and manually clean it with a piece of solid strand steel wire? If not, do so.<br /><br />Any restriction at that point will result in having the engine bog out when throttle is applied.
