Johnson 15hp 1998 J15RLECR - Rough Idle
BarraTheFisho
Hi there guys,
I'm new to this forum and in hopes of finding a possible solution/fix to my Johnson 15hp 1998 J15RLECR that isn't idling that well. I bought this engine on a jon boat and the owner said that there was no problems with it. I run it on muffs as i get home and she idles fine but i do notice that on the lower leg just on top of the hole that the shift rod is in, it leaks water, anyways i continue to carry on and take it out on the water for a spin. I get to the boat ramp real early in the morning and try to start the engine, it starts alright but unlike when it was on the muffs, it was not idling, it would just simply die. when i took it home i hooked it onto muffs and ran it and she idled fine?? I don't know whether this is a seal kit fix or something more major on the internal components of the engine?
Mohawkmtrs
Open up (turn counter-clockwise) the slow speed needle valve 1/8 to 1/4 turn.
You can also adjust the idle speed on the end of the tiller.
