1989 150 one year on rebuild. Temp gauges both heads. at just above idle in gear 200 left, 140 right. cant hold hand to left head. Verified with infra-red. pulled t-stats, same. strong stream from ind tube. pulled ststs and housings, started and ran. good water flow out stat opening on right head. Almost none on left, same at all speeds.<br />What is the water path from pump through engine?<br />Any ideas?
