Johnson 150 Ocean Pro J150EXEDB V6 will not idle after it warms up
TSinTX
A couple of issues here. I recently had the carbs rebuilt, new fuel pump, filters, plugs, etc. The motor will start just fine from cold and run for several minutes but after it warms up it sputters and dies. Once this happens I can keep pushing the key in to purge more fuel to keep it running, but once I let it go it just sputters out again. The fuel is fresh and clean. I did find that on the middle carb on the left bank has the needle valve broken off flush with the place it threads into. I learned of this when I could not get a new needle valve to thread into the slot. See photo. I am not sure if it has anything to do with the problem I have and really not sure how to remove it. Any ideas on warm idle adjustment or what to try? I am at wits end and do not want to throw much more money at it. I just spent over $2000 to get this running and it still is high and dry.
Honorary Supreme Mariner
Did you ask to have the carburetors rebuilt ?---Or was it the decision of the shop ?----Did you ask to have a new fuel pump installed ?-----What other trouble shooting was done ??
Chris1956
Well, it sounds like the shop who worked on it did an incomplete fix. Did they break the idle needle?
You might check the idle timing. When the Quickstart is engaged, the motor should run at about 1200 RPM, due to the advance in timing. Do you have the timing specs and knowledge to set it? If the timing is correct, it is likely the carbs are adjusted incorrectly.
WrestleSmart
If you have a very dark area take the cover off start the motor and look for spark in and around the coil areas and the spark plug wires. Mine did that for years then I rebuilt the carbs still did it. Once I checked it at night and looked very closely I could see sparks faint but present in several areas. Changing the coils and spark plug wires fixed it.
