Johnson 150 no start, backfiring
JOE400SBC
Hi guys, I'm looking for some input on my 95 Johnson 150 Faststrike that up until today has run great. I tried starting it the other day and it cranked for about 20 seconds before backfiring out the exhaust. I had pumped the primer bulb as it had been sitting for a few weeks so I figured it was just flooded. I tried again a few more times but the engine just backfires extremely loud out the exhaust and it kicks back while cranking as if the timing is off.
It has always started almost immediately even after sitting and ran great when I last parked it about a month ago.
I am getting spark and fuel. No air leaks in the fuel line that I can see.
I did get it to start once and it seemed to run fine for a few seconds before I shut it off, but I couldn't get it to restart and it's back to backfiring.
Any ideas? Sheared timing key? Optical sensor?
Thanks -Joe
JOE400SBC
update: I checked for spark again and it seems there is only one spark and then nothing. I turn the key and it will spark one time and then not spark again.
ondarvr
Backfiring through the exhaust is normally a sheared flywheel key.
phillnjack2
Ensign
I would check the flywheel key too.
take out all the plugs and take ignition key out too.
turn motor over by hand and check where no 1 piston is when the timing mark is at tdc.
if it is out even a little a bit then like said above the flywheel key has sheared and flywheel moved a bit. this is not un-common.
JOE400SBC
I checked the #1 at TDC and it's right at the mark on the flywheel so I'm not thinking it's the key.
I noticed the #1 cyl sparks the instant I turn the key to crank, only once, and then it won't spark again. I'm guessing this is where the backfiring is coming from, the engine loads up with fuel and then It sparks once and backfires.
I have a Clymer full service shop manual but there doesn't seem to be a test procedure for the power pack or optical sensor.
Honorary Supreme Mariner
I do not believe there is a flywheel key on this motor.----------There is a key on the timer wheel I believe.
flyingscott
I believe you have an OIS ignition no flywheel key. Check the optical sensor.
JOE400SBC
Correct it is OIS, I just pulled the flywheel to take a look at the stator and it appears okay. It ohms out within spec.
I cleaned the optical sensor and it made no change. I don't have an oscilliscope to test.. is there another way to check if it's working?
Thanks for the suggestions.
