I have a 1999 23 Sea Fox with a Johnson 150Hp. I am not sure what year the motor is, but I am pretty sure it is a 1999 also.<br /><br />The problem I am having occurs after approximately 30 minutes of use, or when I get out of the inlet (I am located in South Florida by the way). He engine runs great for the first half hour and then all of sudden starts to run really rough, and the whole transom is shaking. If I put it into gear, it has very little power and at full throttle I might have a speed of 5-10 m/h. Eventually the engine will die completely. When I try to restart it will turn over, but the RPM at idle will be over 3,000 and there is no way to slam it into gear.<br /><br />After this phenomenon occurred the first time I changed the plugs (I have followed the suggested service schedule on the motor since I got the boat new in 1999) and next time I put the boat in the water the engine started and ran just fine for 30 minutes until the same problem occurred again. <br /><br />If someone has any idea of what might be wrong with my motor Id be very appreciative.<br /><br />Thank you!
