arctic_dan
Thread starter- Joined
- May 25, 2017
- 28
Off with the carb again. Will check the bowl vent again. I know it is not plugged. But maybe its semi plugged and not letting enough air in.
Granted I'm a complete newbie to outboards, but not to engines in general...
Unless you have precision machine work equipment, I would NOT drill out the jet to make it bigger...
They are precision orifices, and you don't even want to scratch them with brushes, wires etc... Throws them out of spec...
(EDIT: Also, without precision machining tools, you'll never get the accuracy you need to get, to have it worth anything at all...
Would probably make things worse actually...)
Just my 2 cents....
