arctic_dan
Thread starter- Joined
- May 25, 2017
- 28
Hey guys, Im new to the forum. I signed up to see if anyone can help me on my old school Johnson 15 hp outboard motor.
The problem: The motor will run and start fine but when I put it to full throttle it will die ad run erratic. I can pull the choke and it will get up and go like hell and run great but when I take the choke off the problem persists.
What Ive done: Ive taken it all apart and changed the pump gaskets,seals & diaphram. Cleaned the carb, changed gaskets/seals. From the gas tank all the way to the carb there is good flow when I pump the primer bulb.
I took it apart once again and realized that the airbox nipple that presses on the carb is worn right out and not sealing on the carburetor. Could this be the problem? At this point Im not sure what else to check and don't want to buy a new airbox if thats not the problem. Any help would be greatly appreciated!
