Johnson 15 hp 1990 throttle cable play?
Alex.L
Hi everyone,
Been scouring the forum and web for an answer to this, but been unable to find it. Might be I'm using the wrong fraising (english is not my first language).
It feels like my Johnson is not reaching its optimum rpms. First thought was carburetor, since I don't know when it was last serviced. But then I got stuck looking at the throttle cable. I've always felt like it's got quite little "play", with this I mean that the range from bottom to top throttle at the handle is quite small. I hope you understand what i mean.
I'm uploading two photos of the extension of the throttle cable, I don't know if the range is normal or to short? One photo with throttle at min and one with throttle at max. Should it extend further than this?
I have previously set up idle according to Leroys ramblings.
Thanks in advance for any thoughts!
flyingscott
Is the carb opening all the way. The throttle cable has a fixed amt of movement that can't be changed.I Is the plastic roller and cam in good condition?
Alex.L
Thanks for your answer flyingscott!
I'm taking it out for a spin tomorrow, will double check carb opening then. As for the cam, it's in good working condition. I'm a bit unsure about what you refer to as "plastic roller". Is that the round plastic ball held in place just inside the lower engine cover (on the throttle cable)? If it is, it's fine and tight.
Edit: to clarify, the cam looks good, no ware and tare, but I haven't done anything with it since I bought the outboard.
Alex.L
No Title
Further clarification.
Red is what I'm thinking is cam and green is what I'm guessing is plastic roller?
flyingscott
Yes and that cam is adjustable. The roller should come pretty close to the end of the cam when the throttle is wide open. You will not have full throttle unless the motor is in gear. Neutral has a throttle stop to prevent overreving in neutral
Alex.L
No Title
Thanks again!
Just removed the air silencer (?) and this is what I found. One pic at min throttle and one at max, not even close to the top. Also, the screw (red) is only attached to the outer piece of the cam, in other words it's kind of loose.
I'm quite confused atm,so I apologize for my rambling.
Edit: these pics are in forward gear (same as above).
Edit 2: the carb is open all the way.
Alex.L
(Sorry for the multiple posts, couldn't edit anymore.)
It might be as simple as a faulty throttle handle. Was going over the motor and suddenly struck me to check the actual handle. When I took it apart, parts flew everywhere. Plastic inside was cracked. I have modified it somewhat for tomorrows outing, will check back after that!
Alex.L
Yay, it's alive!
The biggest problem was the handle it seems. I still believe that I need to clean the carburetor, but it's running much better now.
Thanks again flyingscott for your guidance!
