Johnson 140 Seahorse V4
tridar
Hi I was just wondering if you could give me some advice on my engine compression. We recently had it compression tested and were told that cyc 1, 2, 4, had 150 psi and 3 had 125. What could be the cause of this??
JB
Re: Johnson 140 Seahorse V4
That's a little out of spec, Tricia, but not necessarily a sign of major trouble.<br /><br />A thorough decarbon treatment is the next thing to do, followed by a repeated compression test.<br /><br />Good luck, and let us know your results. :)
OBJ
Hello tricia and welcome to the iboats forums.<br /><br />A low compression can be caused by several things.<br /><br />Stuck rings, perhaps a score in the wall of the cylinder, a blown head gasket.<br /><br />Probably the first thing to do is give the engine a decarb then retest the cylinders for any improvement. 25psi lower than the other cylinders is a little outta the ball park of 10 to 15%. But don't dispare. Give the engine a decarb and receck. Next I would look at the head gasket and replace it if it shows signs of leaking. And with the head off, the condition of the cylinder can also be checked.
G DANE
That being said, 125 isnt low compresion for a V4, lots run very fine with 115 and 110. 150 is like new. I think the highest they ever had.
G DANE
I would like to take a look at the carb on the low cylinder to be sure it isnt in lack of fuel and oil. But these motors tend to carbon up one cylinder, the lower port , I think.
R.Johnson
Here is one case where a compression reading on a two cylcle engine can be misleading. It's that #150 cylinder that is way out of spec. I have run into this many times. I would be willing to bet if you pull the cylinder head, that piston, and cylinder wall is damaged. Why it will pump higher, I'm not sure. Short of pulling the head, a leak-down test would tell you more. Let's see what the other guy's have to say.
OBJ
Guys...ya' think they did the compression after the engine had sit a while and was stone cold? Seen some weird stuff on cold compression tests. Maybe what they need to do is run the engine a while and get it warmed up and lubed. May be a different story. Then as R.J. suggested, a leak down would be the next step if they got the set up.
G DANE
R. Johnson - maybe the ring gaps get sealed with aluminium filings. I dont like the thought. I´ve got 3X 125 and 1 with 135 myself, cold. Havnt run it yet. <br /><br />Since you have 3 equal and on lower, you are probably OK.<br /><br />Some shops have a Scope that gives a good look at cylinder walls without removing heads. If you take the boat there, maybe they will take a look. But I would take a reading when motor is warm first - probably no problems then.
tridar
Originally posted by tricia:<br />Hi I was just wondering if you could give me some advice on my engine compression. We recently had it compression tested and were told that cyc 1, 2, 4, had 150 psi and 3 had 125. What could be the cause of this??
tridar
I took the boat to the boat shop and they told us there was something seriously wrong down below and that to fix it would cost $3500 - $4500 AUS and all they did was the compression test. Thanks for your comments
Dhadley
I would start as JB suggested. Have you done the de-carb yet?
Cricket Too
Sounds to me like that shop may be scammin you. I would follow the instructions here and then take it to another shop. $4500, you could have a new(used) motor for that. Do the de-carb, and even if there is a problem you'll probably still get alot more time out of that motor. Good Luck.
tridar
Hubby got the stuff to do the decarb all we could get is the one you put in your tank he is going to do it tonight when he gets home from work.
