Johnson 140 looper timing
thatone123
Banned
I've been fooling with this Johnson 140 looper for a while now. Not exactly what year as the id plate is messed up. Motor has 120 psi and in good condition. Rebuilt carbs meticulously.(4 of them) Engine will start with some starting fluid and manually pushing the timing/carb lever forward. Once it get to operating temp it will start and run. It is a jet unit and blows all the water out of the tank, so cannot run it long. The timing mark at 22 degrees seems to be about almost 3 inches to the left of TDC when I turn it over with plugs out. Adjustments don't seem to do much. It idles high, but seems to run good. The link and stink lol procedures seem a little Greek to me, but there seems to be no big deal there, as the adjustments don't seem to change much anyway. Help!
Bosunsmate
Might need to check flywheel keys stiill in place.
Or check number one cylinder is at tdc when flywheel tdc is at the pointer on the side by flywheel
Baylinerchuck
I had an old Johnson that was giving me fits. I thought the timing was screwed up and suspected a bad timer base. When I would use the timing light to view the ignition timing the pointer jumped all over the place. This was an 85hp and had 2 power packs. And the spark was irradic on all 4 cylinders. Engine would run on choke and high throttle but wouldn't idle. After swapping out the timer base didn't change anything, I put two new power packs on it. Problem solved. It was very difficult for me to believe both power packs had the same issue. My experience is that they just die.....instead of producing crazy timing.
thatone123
Banned
Well, yes, that is what many say is that the power packs just quit. Anyway, Took this rig out today to test on the lake. Low and behold it started and ran. I tried all the things the Soloc book says to do to the link and stink, but none of it seems to apply and not much change happened. The motor seems to have a miss but ran good up to 6000 rpm with all throttle butterfly's open, so I don't know much else I can do. Alright for now. Thanks!
