Hello all. I have been looking everywhere for information regarding the normal compression numbers for a Johnson 140 outboard(up through 1994) and have learned that the variation between cylinders seems to be much more important that the actual pressure, which is understandable. However, I have also learned that the later model engines might have lower compression than the earlier model engines. My question is; Was the compression lowered on 140 outboards( to compensate for lower fuel octane ratings) and if so, what year model did that occur? I am going to look at a 140 Johnson and would like to know if the engine is within the expected range. Thanks in advance for your help.
