Johnson 135 question
henryban
I wanted to know how the pistons and cylinders looked after three years operation in saltwater, after using eleven dollar synthetic all that time.<br /><br />I removed the head on one bank. <br /><br />The two cyl's walls looked perfect, no vertical scuff lines at all, and the crosshatch lines clearly visible.<br /><br />The piston heads had about .030 carbon build up.<br /><br />The inside water walls looked very clean and free of buildup.<br /><br />The only negative was very small corrosion pits near the outer edge of the surface of the aluminum cyl. wall.<br /><br />I don't know if bothering with the other side will do anything to slow down the corrosion.<br /><br />Questions:<br /><br />Do I bother with the other side?<br /><br />Is there a best brand replacement gasket?<br /><br />Thanks
OBJ
Re: Johnson 135 question
Hi Henry<br /><br />Sounds like the engine has had some top notch PM over the three years. Regular decarbing will take care of the carbon build up on the pistons. Not a bunch you can do about the corrosion pits. Just remember to flush her out with fresh water after a day on salt. Even us fresh water boys get the "pits". Do compression test on the other side and if they read good, I wouldn't open it up. Just an opinion on head gaskets, I perfer OEM myself but after markets will usually work just fine. Good Luck and keep up the preventive maint. :D
henryban
The motor sits at a saltwater slip all the time. Too difficult to use muffs. Never gets a freshwater flush. Wish I knew a way.
12Footer
There is a way,provided you have a fresh water source to reach the boat. the negines can be fitted with flushing ports and pulse units that take the place of a running engine to flush it.<br />I'll look for the link,and post it ere when i find it.<br />Ok here is one (not the one I was looking for, but close.<br />The one I'm trying to find is used by the NAVY,on thier outboards,and smaller I/O's , and is called pulsejet or something..(see, if I could remember the name,I could web search it)<br /><br /> FLUSH KIT
