Johnson 115hp VRO help
Barney Fish
I have been struggling a bit this summer with my Johnson 115hp vro warning system. The "low oil" alarm kept going off even though the tank was full so I took the least expensive option and disconnected the circuit. Then, the "no oil" alarm kept going off and when I cut the engine to check it out.....it would NOT turn over...not even a click. I bypassed the solenoid and jumped the starter and it started right up. Measured voltage across the solenoid and it was 0v. Does the vro alarm system prevent you from starting your engine once it goes off? <br /><br />I also don't believe that the vro system is not pumping oil because I seemed to burn it. Just to be safe I added some to the tank (50:1) and I may end up removing the vro system if indeed it is failing.<br /><br />Any help and advice would be appreciated. :(
OBJ
Re: Johnson 115hp VRO help
Rich...welcome to the forum...<br /><br />The VRO pump don't have nothin' ta' do with the motor starting up unless the pump went south and the block is trash...so...<br /><br />If you had 0Volts at the small solenoid terminals, it is either the start in neutral switch inside the control box or if ain't nothing else working either when ya turn the key on, check the fuse on the engine. Little red fuse holder on the port side of the engine (that's the left side facing forward to landlubbers). <br /><br />And ya' need to post the year of the engine also. If ya' aren't sure of the year, post the model number. <br /><br />Thanks.<br /><br />By the way, you can replace the VRO tank unit. They do go bad on occasion.
jfalet
I am having a very similar problem with my 1993 175 evinrude. My oil alarm goes off intermitently and the only way to stop it is to shut engine off. I had the vro pump replaced but it still happens. Can you tell me how to disconnect the no oil sensor?
