johnson 115 no spark on right side of motor
exrex0015
got a 96 javlin from my father in law he just had power head redone, boat infested with termites, condition wostened after having for only 6 months boat ran great took it out sevral times 20 miles a time ran no problems got another boat and decided to swap motors after the new boat started knocking, again johnson ran great right before, got a remote control box for motor and carefully removed all engine wiring from old javlin boat and ran exactly how was hooked up in javlin on new boat. after sevral days of getting everything right, tried to test fire engine finally and wouldnt start at all! went to check spark plugs have good spark on left side no spark on right side moved plus same result moved trigger wires from left and hook on right i get fire on the one i hooked up with left side trigger wire so i know plugs are good and coils are good cdi was replaced in 2018 so i wouldnt think it went out, un plugged control box from harness and jumped starter no change, cleaned and retightened cdi ground and reset all connections on motor still no change, now i did leave cowl off motor for a couple of weeks and i did rain but its texas and hot and motors should be water resistant right? i got ven unplugged all connections from boat side on motor and still has spark on left but not right side now i have a meter dont have a dva or even know what that is but im at a loss
dwco5051
Shift interrupt switch in control box will kill one side. It's been too many years and I don't have wiring diagrams any more to help in trouble shooting it. I am sure one of the Johnnyrude pros on this forum will chime in.
exrex0015
besides i disconnected all wires going to boat harness one by one and jumped the starter and still only spark on left side
dwco5051
Just reread my first post and realized what I typed. The actual shift interrupter if it did have one is not in the control box but mounted on the engine and actuated by a cam on the shift lever. It has been several years since I had a v6 Johnson and my 84 year old mind sometimes doesn't keep up with my thinking and typing. Here is a good reference for ignition trouble shooting. Johnson outboards start around page 70 https://www.cdielectronics.com/wp-content/uploads/2016/12/7th-Edition-Troubleshooting-Guide_RS.pdf
ct1762@gmail.com
Master Chief Petty Officer
sounds like a pack issue. DVA with load adapter will tell the story, ditto for terminal extenders . if sensor had spark follow to the other bank, its not the sensor.
73 Dolphin
Perhaps try swapping the coils from the left to the right? If you now have spark on the other side replace the bad coils.
