CaptainHook
Thread starter- Joined
- Mar 18, 2010
- 310
Just put a 1990ish Johnson 115hp on a boat for a buddy. The motor fires right up with no problems but wouldn't idle so I started checking things out.
Found one cylinder not firing. Changed the coil and still no fire. Use a jumper wire to another cylinder's connections and the coil fires.
This motor only has one powerpack. Could this be bad? Or does the signal to fire come from another component?
