Johnson 115 Flywheel wont engage
BLong on the Lake
Hope someone can help. The flywheel won't pop up to engage the starter (hope I am using the right terminology). If I remove the engine casing and physically force the flywheel into position and then turn the key, it starts right up. Also, the motor occasionally lurches badly. It will run fine and then briefly miss or something, and makes an ugly clunk noise. It might do this every minute or so, or only a couple of times a day. Please help, i'm at a lost and can't afford to let a repairman fix this right now. Thanks alot.
walleyehed
Re: Johnson 115 Flywheel wont engage
#1, either the bedix (the part that moves up and down on the starter) is shot.<br />#2, your battery voltage is low, which "could" be loose connections, bad grounds, etc.<br />Find a silicon based spray oil and put a very small amount on the bendix shaft (starter shaft)<br />#3, your "clunking" noise sounds like an improperly adjusted shift cable which needs imediate attention as this can destroy your lower unit gears.<br />#4, the flywheel is the gear toothed "frisbee" looking thing on top of the crankshaft.
bubbakat
If you are talking about the starter bendix won't pop up and engage the fly wheel just rotate the bendix up and put a little PB blaster on the worm gear to lubricate ir. Some times low voltage or a dirty connection won't let enough amperage get to the starter to run bendix up.<br /> sense you say you can do it manually just try lubing it if that don't do it change the bendix out on the starter. <br /> hope this helps post back and let us know<br />well walleyed beat me to it
WillyBWright
It's like Deja-vu all over again. Do I hear an echo?...echo?...echo?...<br /><br />Walleyehed wins the Nimble Fingers award. Beat bubbakat by 3 minutes.
