Johnson 115-4stroke
JamieBellman
I have a 2005 pontoon with Johnson 115
4 stroke.
Ran boat today for 2 hours all is good.
Pulled anchor started engine and cruising at low rpm.
Pushed button to lower trim and engine began missing like on a rev limiter. Would not allow throttle. Held down trim button and engine came up on rpm as long as trim button was held down. Let off button and started missing. Eventually died and would not restart. Wouldn't wven turn over.
I have no idea where to begin. Neutral safety switch ? Something tied to trim switch ?
Help please ?
jakedaawg
You have a short in the trim wiring to one of the engine monitoring circuits most likely. This could be a tricky one. There is a 55 pin connector that is the most likely place I can think of to start. Get a manual of your gonna do it your self.
jakedaawg
Oh wait, there was a module that needed to be added to the trim or it would burn the switch out. Make sure you have the module under the helm in the trim circuit. If not get, replace trim switch and test. Or disconnect trim wires at engine and test. They are red green and blue and I believe they have white tracers at the engine side connector.
