Re: Johnson 112 SPL running at 17 volts
The dealer strung a new harness above the deck, determined there was a problem and insisted the whole harness needed to be replaced at a cost of almost $400. I had suggested, finding and replacing only the burned wire but they refused, saying they would not warranty the work if I had another problem if done that way. So in the end, since they could not remove the old harness from under the floor, they never really determined where the problem actually was. They just knew, the engine would start. I do charge all my batteries on shore, but found it easier to charge all at once rather than charging the trolling motor batteries seperate. I put them on an automatic charger that drops to a trickle charge after a full charge has been reached. Due to lights, gauges, tilt and other items that I could not isolate from the main wiring harness, I found it worked better to wire my electronics and trolling motor through a seperate feed, then use to the Perko switch to isolate the cranking battery so I would be able to start the motor at the end of a long fishing day. Charging the batteries while with the O/B while running the lake was just an added benefit. When the motor was putting out 17 volts at WOT, I tried breaking the connection between the cranking battery and the trolling motor batteries and saw no change. Only after I used power with the trolling motor did the voltage output drop. I'll check into the add on voltage regulator, maybe that is the best solution. Thanks for all the help you guys have rendered. It has been quite a lesson in electronics, but way over my head.
